TS1 help
red
twenty eight wrote:
stesjh wrote:Looking at building a TS1 motor and was wondering what your views were on cranks and what type / size carb to use, any views welcome :?:
my set up ts1 mb fast road tune 35mm tmk carb franspeed race pipe six plate clutch 58mm racecrank rb con rod fitted li 150 gearbox 47/17 sproket pulldown chain tensioner high load bearings fitted bgm stator,dont forget about you will need to uprate your suspension brakes tyres fuel tank...go for it :anbrgin;
And don't forget your bank account
:biggrin: :biggrin:
GP Kevo
Does yours pull 4th strongly? I'm at 16 x 47 and feel like I could use another gear after 4th.
warts
Main scooter: honda
GP Kevo wrote: Does yours pull 4th strongly? I'm at 16 x 47 and feel like I could use another gear after 4th.
Oh No!!
stesjh
Main scooter: SIL200
Many thanks for all the advice / opinions there seem to be so many - time for much thought I think :roll:
lockman69
stesjh wrote:
Muttley McLadd wrote:What have you got now?
And, what do you want a TS1 to do that your existing one doesn't?
Just a box standard SIL 200, pretty slow and seized a few times now :cry: would like something with a little more uummpphh and TS1's have been around for a long time and seem pretty tried and tested :)
I am currently running a cleaned up stage 4 , 30mm delly and JL3....it will sit at 65-70 (gps and fat git) all day long, tank to tank, slightly over jetted main jet using a egt the temps remain constant at wot....my TS1 nolonger gets a look in!
Next project, could be to rip off edens engine spec.....but dont tell him :baddevil: :bigsm:
Lockman 69 (Iron barrel believer)
nelson pk
Thats easy to do. Getting it nice and cool at 1/4 to 1/2 throttle at higher revs is the hard bit ;)
That makes two of you then :frog:
Nelson PK (good quality ally barrel believer) :D
lockman69
1/4 to 1/2 throttle....Whats that??? :lol: :lol: :lol:
nelson pk
Good answer :lol:
