idle
Stinky Finga
Morning all
Im having trouble setting up a PHBH 30mm
Tickover is sitting at about 2k'ish
The idle screw dont seem to work
Ive set the airscrew at 2 turns out
I can bring the tickover down by turning the airscrew out
Am i right in thinking ive got an air leak somewhere ??
twenty eight
have a look at the carb rubber you could have a split in it or you could have a split manifiold gasket
Minority
Main scooter: Li230 S3
When the idle screw didn't work on my 30PHBH it was simply that the throttle cable was adjusted too tight and the slide wasn't closing all the way. I loosened the adjustment at the top of the carb and "hey presto" the idle screw worked.
Sometimes it is the easy things. :biggrin:
