Exhaust with best ground clearance
Avantone
dopeshots wrote:Hi everyone I am looking for some advice on exhausts.
I run a highly tuned Imola 186 running a JL Race pipe in a full frame scooter.
Trouble is when tear assing about I tend to grind the RH Side of the exhaust on the floor round roundabouts.
What has more ground clearance without loosing what the JL Race pipe gives my engine?
Cheers
:fb:
How are you doing for inlet manifold clearance? You could try an adjustable shock to increase ground clearance if you haven't already.
Tony
www.lambrettagearbox.com
dopeshots
Xbox live gamer tag: rms789
Main scooter: GP150
[quote][quote="Avantone"]How are you doing for inlet manifold clearance? You could try an adjustable shock to increase ground clearance if you haven't already.
Already got an R6 rear shock on it.... works well but just keep hitting the road with the exhaust.
Stampede
Main scooter: SX200
R1/R6 Yamaha conversion shocks are the shortest, which means that your exhaust comes closer to the street.
Try a longer one, BGM or a Series 2.
dopeshots
Main scooter: GP150
Hi thanks for the pointers ref the rear shock but I'm after exhaust info please.
Someone must know about ground clearence on exhausts?
Russ :|
