remade phosphor bronze bushes
chez
Main scooter: li150 special
hi, anybody know who does quality remade clutch bushes not the indian floor sweepings compressed into shape :?: ;)
Special X
Scooter loopy john does these. Don't know his contact details though.
Minority
Main scooter: Li230 S3
Special X wrote:Scooter loopy john does these. Don't know his contact details though.
Try this:
http://www.freewebs.com/scooterloopy/contact.html
warts
Main scooter: honda
Did you have a bad experience with the floor sweeping ones? Sintered bushes like these should be soaked in oil prior to fitting. Last a life time. That is until it dies.
chez
thanks for the contact details, johns site doesnt have them on but i have sent pm and email so hopefully will be able to supply. @ warts no bad experience personally but friend who has fitted many warned against them so better safe than sorry,
mickdale
you could always try the loose glued in ones from resurrection lol
nelson pk
Camb lamb do a quality one with an oil way machined in. More expensive but its what i use and i've never had any problems.
tea5ive
Main scooter: cometa 140
warts wrote:Did you have a bad experience with the floor sweeping ones? Sintered bushes like these should be soaked in oil prior to fitting. Last a life time. That is until it dies.
as warts says sintered bushes should be soaked in oil prior to use. in other aplications the phosphor bronze is sintered together (heated until the grains of metal stick to each other leaving gaps our porousity ) they are usualy pre formed rather than machined as machining smears the surfaces trapping in the lube our preventing the lube getting in. they are then placed in a vacuume and the lube oil is sucked into the porous bronze. the ones with the oilways machined into the bronze should be fine . cheers simon
chez
no reply as of yet from scooter loopy john thanks again for all comments, will look into camb lambs bush tho def not using scooter restorations bush lol
    Users browsing this forum: Google [Bot], Semrush [Bot] and 27 guests
