I picked up a set of sip tubeless yesterday and both tyres were at 30psi,
i obviously had to get the pressures right so i went to the garage and on one of the wheels,the valve is too short to get the airhose on??
i tried another garage but had the same problem.
anyone know a fix for this?can i loosen the nut on the valve and screw the valve so it sticks out more?will this cause a potential air leak?
do i take em back?
The other valve seems to be sticking out TOO far,double the short one.
SIP tubeless valves
- molibdimum
As mentioned before..
http://www.amazon.co.uk/90-Degree-Schra ... 736&sr=8-3
Or could try one of these...
http://www.amazon.co.uk/L-S-Engineers-M ... m_sbs_sg_4
I'm taking em back, I'm not paying good money to have to go modify em.
On top of all that, one of my rear hub studs is stripped.
stuckintheeighties
- Main scooter: SX200
Small bike pump in toolbox. pound shop sell them for guess how much?
- molibdimum
Received two of these in the post this morning.
Quality piece of kit and does the job to a tee.
Keep one in the garage and one in my bike jacket.....sorted.
turned out the valve was no good anyway,took it back and got it replaced.
