nylon bush
gideon
Just fitted new nylon bushes to my fork links but they are to tight to put the metal pivot bushes through ,has anyone else had this problem , and how did they overcome it?
Knowledge
I bought a lathe and made my own bushes, that's how I overcame it.
You can use a reamer to remove some of the ID from the bush.
You can use the jaws of a vice to push the metal sleeves in, but there should be some movement here. If they are too tight, it is not ideal.
You could send the bushes back and ask for some that fit.
Martin
the white ones always seem a bit of a knightmare............the grey type a bit less so........... :? :lol:
black ones seem quite good from my experience so far.........but i,m sure other folk may see things differently...........
knowledges solution is the best in this respect...................... :D
rog60
Main scooter: Indian GP200
IMO fitting link bushes ranks equal first with trying to get the 'bridge' piece to fit neatly.
i use brass ones with a spiral groove in them for the grease ,the links need to move freely when everything is tight , i trial test mine before i fit the springs and rods i susspect that if one link is tight thats why people scoots pull to one side esp when braking
storkfoot
I've had this problem with the white ones. I binned them and bought a set of black ones from MB which were, by comparison, almost finger push in.
gideon
its the white bushes im having trouble with. i pushed the metal bush in halve way with a vice but gave up when i realised there wasnt going to be any movement
send them back and spend a little more on the mb ones .
I've helped fit a set from MB. Half an hour with some 80 grade sandpaper to get them to fit.
gideon
ive just tried mb bushes still impossible without vice i think i need a reamer can anyone help with what size i need price etc thanks
    Users browsing this forum: Semrush [Bot] and 13 guests
