Monza Short Manifold needed...
J1MS
Does anyone know which is the shortest manifold to fit under the panels on a monza 225 with a Dellorto 30mm Carb fitted....... Thanx ..........
"jimmers" manifold will give you the most clearance but you'll need to PM him to see if he does a bolt on rubber for a 30mm carb. I have the manifolds but only have the 35mm rubbers.
