What manifold should I get for a Mikuni TM24....????
oioivespaboy
I've got a series 1 framebreather with S3 Li150 engine and TV200 top end and I'm currently using a Jetex 22mm carb.
Not happy with the Jetex so want to change it out for a Mikuni TM24 that I have sitting around but I need to know what manifold to get. I tried sending an email to MBD but haven't been able to get a reply so thought I'd try here.
When I hold the Mikuni up to the standard manifold the Mikuni sits too low and hits against the mag flange/cylinder shroud.
I'm on the other side of the world from most of you so just want to know what will work before I try and place an order.
Thanks
I used the MB one on a Mugello 225 and TM24 carb. No clearance issues that I recall.
http://www.lambrettaspares.com/spares/2 ... 0050k.html
Send me a PM if MB are out of stock and I'll check if I've got any stock, I know I've got 150 versions but not sure about 200+cc.
mickdale
get one with a groove for the rubber
ive had ones without and the mikuni always came loose when warm - i even tried loctiting the rubber on
