Max size airhose
soosh
Anyone know the max.size airhose you can get? Im guessing run remote filters on TMX35`s and Dellorto 34`s.Ive seen on on Cam Lam`s site and its 55mm but wondered if there is bigger?
Cheers
Stampede
Main scooter: SX200
The 55mm one would fit a 60mm TM35, too.
soosh
Cheers chaps,think 60mm is going to be the minimum as im going to have to machine down the bellmouth on it anyway as its about 64mm.
you can get it in 65mm
http://www.ebay.co.uk/itm/Blue-Silicone ... 1e646c11a7
pricey tho...
I have an amal and it's about 57mm diameter and the SPaco / dellorto is about 60mm
soosh
Cheers.
The breath sweet 60mm will fit a 34mm Delly, you need to have the carb in your hand to do it though, I'm not sure I'd have managed it in situ though.
soosh
I'm trying to fit it on a Tillotson HL carb.
The Delly is 64mm.
soosh
That size sounds perfect.Cheers.
