Thin ring/quality piston options for standard GP/200dl?
vegansydney
What are my options for a quality 66.0mm piston with thin rings? Its for a standard GP/200dl so a MBD RaceTour is probably overkill. Looking for something with a full skirt (71mm).
Muttlyoo7
Main scooter: Gp200
vegansydney wrote:What are my options for a quality 66.0mm piston with thin rings? Its for a standard GP/200dl so a MBD RaceTour is probably overkill. Looking for something with a full skirt (71mm).
Asso pistons are good and don't break the bank. AF use them in a lot of thier kits.
mickdale
arent the inlets cut though?
Muttlyoo7
Main scooter: Gp200
The pistons for piston ported barrels such as the standard iron SIL or the Rapido series aren't cut. However you can have the inlet skirt raised a few mm on request.
soosh
Does it have to be a thin ring?
vegansydney
soosh wrote:Does it have to be a thin ring?
Preferably, but I will consider other quality options. What do you have in mind? Thanks.
soosh
I've been using a Mahle which was recommended by the person who did my barrel.I run it on the two top rings only.My piston had been modified/cleaned up but yours is std spec anyway so will be fine.My 1st piston covered approx 8k before I replaced as I stripped the motor.It's still a good spare.
goldeneye
same. running a Mahle piston with just the top 2 rings in my cleaned up indian 200 barrel. no problems, runs a 30mm carb and clubman exhaust.
mickdale
soosh wrote:I've been using a Mahle which was recommended by the person who did my barrel.I run it on the two top rings only.My piston had been modified/cleaned up but yours is std spec anyway so will be fine.My 1st piston covered approx 8k before I replaced as I stripped the motor.It's still a good spare.
thanks for the info soosh - 8k cant be bad and they are only 30 quid or so from scooter restorations :-)
soosh
I'll dig out the clearance that was recommend as there are different grades of piston,I'm sure there was a + size on the std 66mm piston.
    Users browsing this forum: Semrush [Bot] and 25 guests
