SIP TUBELESS WITH Schwalbe RACEMAN Question
philhnottm
Main scooter: px (s)
Just fitted a set of these to a P2 Disc
Space between rear tyre and RH JL is very very tight. Is This normal ???
Gather i dont need extra spacers , washers etc They seem bigger tyres thanthe Coni's that i took off.
Also is it worth putting Puncture Gel inside like i did in my old tubes???
Any advice welcome
Thanks
Phil
tomdavid1988
Hi Phil, it is normal for there to be very little space between tyre and JL exhaust, I wouldn't pack it out with washers as it starts putting stress on the exhaust.
I don't bother with the goo in mine, but I suppose it is good practice.
fraserp200e
Main scooter: 1988 MotoVespa TX200
Keep an eye on your rear shock as well. My schwalbe raceman tyres were rubbing - especially when it's loaded with gear - I ended up putting a wee spacer washer between the hub and the wheel for a bit of extra clearance. Mine were split rims though, not tubeless.
1983 Vespa PX125
1984 MotoVespa P200E
MCH
Main scooter: street racer px
the racemans have a wider tyre wall than most other tyres, you will find they look a lot wider too because of this, even though the tread pattern will be the correct width as stated on the tyre,
gimp1971
Main scooter: vespa t5
i had trouble with racemans with my scorpion they rubbed so got rid of it and put a taffy on that worked also hiedenhau spelt wrong i know are thinner
philhnottm
Thanks to all
Made a big difference , now fitted to all scooters.
Regards
Phil
Tom ( all rims and hubs spot on thanks to all at WSP)
    Users browsing this forum: Semrush [Bot] and 8 guests
