Sportique
gpts1 wrote:Thanks Guys,
Getting closer to getting some primer on it,
Frame is Douglas
Lammy GP200 fork, top half Vespa
ET4 top bearing, VW gearbox bottom bearing, Custom made fork tube
SS180 headset
GP turning front mudguard, modified to look LI.
Engine is Polini 208, widened exhaust port,ported casings
28 Keihin, Mikuni pump.
stock PX 200 pipe
left hand pod is now gas tank, with a header tank under gas cap
Old SIP rear disk been heavily lightened with the CNC, and modified to made it easy to remove rear wheel, SSC rear disk master cylinder.
You're not German are you? :lol:
gpts1
No! A kiwi but thanks ;)
gpts1
New custom painted speedo turned up today from Speedo King, Torrance California, Looks fantastic!! 8-)
gpts1
Newly reCNCed bracket for rear disk, much lighter!
gpts1
Finished remounting the LH side pod so the Glass tank will fit in, Next weekends job glass in all the fitting into the tank and get it sealed up.
That's going to be stunning, some very nice touches, I'm impressed.........but not as impressed as I am with the plasma tv on the workshop wall, I like your style 8-)
gpts1
coaster wrote:That's going to be stunning, some very nice touches, I'm impressed.........but not as impressed as I am with the plasma tv on the workshop wall, I like your style 8-)
Thanks Coaster, My mate that lets be use his shop decided he spends more time in his shed than at home and reckoned he needed a good telly.
Got the
engine back from Retro Scooter Today(Thanks Kev and Andrew!)
Fitted Gransport piston and Mallossi upgear fitted + Vitron seals
Heya Nicholai, when's the paint going on?
gpts1
Hi Matt, have all the paint, decided on Porsche Sepia Brown.just double checking making sure i have every thing done before i put any on.
maskie66
not a lover of vespa's but that is very impressive indeed. lets see more pics :-)
