sip tubeless valves
Dell Oughta
Is there some sort of adapter required with the sip rims /valves as the petrol station air pumps don't seem to work with them (I had to take them to a tyre place to get some air in them)
By the way they are easy to fit tyres to (after watching the vid on the sip site, I did both in half an hour) :D
Mike
Muppet
you could use one of these
http://www.amazon.co.uk/90-Degree-Schra ... 736&sr=8-3
i have; just screw it onto your tyre valve inflate then remove and keep it tucked away somewhere safe till next its needed; works for me, :)
muppet,
C’est la vie
Muppet wrote:you could use one of these
muppet,
Ahh, I found one of those laying on the floor near a forecourt airline, didn't know what it was for but chucked it in the toolbox (unmanned self serv garage) nevertheless. New it would come in handy :fb:
Dell Oughta
Cheers Muppet
Mike
doggbhoy
is anyone else having trouble getting air into their sip tubeless lambretta rims?
i just wasted 4 quid on the above adapter and it bottoms out before it completely releases the valve.... ending up losing air.. :roll:
anything else available?
thanks
:idea: adapter fixed..took a bit off it...duh! :oops:
TS1-200
Dell Oughta wrote:Is there some sort of adapter required with the sip rims /valves as the petrol station air pumps don't seem to work with them (I had to take them to a tyre place to get some air in them)
Mike
Where abouts is it on the SIP website, I can`t find it.
Keep on keepin on
Found this on Google under SIP Sccoters http://www.sip-scootershop.com/main/bas ... n=branding
    Users browsing this forum: Semrush [Bot] and 38 guests
