70,2 piston choice.
ArKaTxU
Hi.
I am searching a good piston for a seized Rapido 225cc in 70,2 or more.
Can you tell me a good choice?
Thanks
tavspeed
try afrayspeed,asso thin ring about £90,or mahle about £66,had both in stock when i enquired.
DaveTomo
Main scooter: SX 200
could be worth contacting Ron Moss and see if he does the Mitaka pistons in the size you require. http://www.supertune.co/index.php?route ... duct_id=53
grimspeed
Main scooter: gp 283 kx
Or go suzuki er 250 !
DaveTomo wrote:could be worth contacting Ron Moss and see if he does the Mitaka pistons in the size you require. http://www.supertune.co/index.php?route ... duct_id=53
Unless it's changed recently the avanti pistons are only available in nominal 70mm ( "A" piston is 69.97mm "B" is 69.98mm & "C" is 69,99mm - Ron's measurements), there's no oversizes.
ArKaTxU
Then, I think that the best option is Asso or Mahle pistons. Avanti dont do more than 70mm and Suzuki 250 piston need 18 pin conrod.
Thanks!
Darrell Taylor
Main scooter: LAMBRETTA
theres a 1mm ring asso rapido piston at 70.4mm thats the best choice
ArKaTxU
Darrell Taylor wrote:theres a 1mm ring asso rapido piston at 70.4mm thats the best choice
Yes. Is the one that I have see in AF catalogue.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 15 guests
