New RB Ceramic 230cc Engine
trev t wrote:is darryl any good, i have never had a tune done by him,,is he fair with prices,,,
Very good. Not seen any of his work, but seen the power graphs and that speaks volumes, check the dyno graph section if you want to see them. No idea on his prices.
Dono
His pricing is not the question, it's can he deliver what you ask for!! The first time I kicked it off and took it for a spin. it put a big fat smile on my face. He tuned the engine to exactly what I asked for :anbrgin; Once I swap the new AF clutch (slipping) and get him to dyno it I will post up the results...
The funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it.....
http://scunthorpesilhouettes.co.uk/
Dono
Dono
Dono
Dono
AF 6 PLATE ROAD CLUTCH 46T Removed after 1st Test Ride - Busted!!! New AF RAYSPEED SURFLEX CLUTCH 46T fitted - Sorted :anbrgin;
Yes I adjusted the chain and bent tabs over Red after Photo taken - :anbrgin;
Dono
philtrate
Main scooter: LAMBRETTA GP RB225
Hi what actually happened to your first clutch as I've just fitted one of these and now I'm worried having spent all that cash.
phil. :cry:
philtrate wrote:Hi what actually happened to your first clutch as I've just fitted one of these and now I'm worried having spent all that cash.
phil. :cry:
Yes, i'd like to know more about that too, as i was thinking of trying on of thier 'cheap' 6 plate cassette clutches?
They have the expensive on here: http://www.afrayspeed.co.uk/index.php?p ... buteID=CLU
And the cheaper one here: http://www.afrayspeed.co.uk/index.php?p ... buteID=CLU
I would have presumed (maybe incorrectly :oops: ) that they both use the same plates and springs and the only difference was the machined parts? Therefore they should both handle similar horsepower....yes/no??? :? :?
Give us more info on the clutch problems....
Dryballs
The new cheaper ones aren't available yet so I'm presuming it's not that
I am here: http://tapatalk.com/map.php?itynqb
