Mickeck copy
The Snail Mickeck you have in a photo used to be mine, sold on ebay about 3 - 4 months ago.
I have a couple of old Mickeck, one is a Mk5, the other is an empty pipe, bit strange.
Mk5 has had some weird welds done along its length.
Will fish them out in next week and advertise on here for anyone who wants
ahh yes ,i was tempted to have a dab on that for a series one ..hence i saved the picstokky wrote:The Snail Mickeck you have in a photo used to be mine, sold on ebay about 3 - 4 months ago.
this is a mickec copy
what do the mickeks rev to,on say a stage 4/5 barrel?
had a mark 5 years ago,but no rev counters back then. I do have a dj available to copy,how much was the copy mickek?
fred
fred
as i said ...if all those that want one club together the cost per pipe falls ,a one off will be around £150 - £200 by my estimate but you would need to get your scoot to york and leave with the guy as i not prepared to use my gp for fitment for one offs ,i would though for a batch of say 10fred wrote:what do the mickeks rev to,on say a stage 4/5 barrel?
fred
i do have a s1 frame for such a task though if any one needs series 1 / 2 fittment
should add that it doesnt have to be a miceck to copy ...if you have a pipe that works ...copy that to look like a miceck
Did the Mikeck fit with runners on?
Got the same pipe but was told it for cutdowns and poss' even not for use with a kickstart...never fitted it so haven't found out yet?
Anyone else found this? and anyone swapped from an AF Clubman? I like a good bit of torque and not a screaming revver but I'm tempted if it will be OK.fred wrote:i've run one,revvy 8+k in 4th needs bracket fettlin to fit right. But can be taken on/off in no time.
