Anyone got any photos of how they've fitted speed sensors for digital speedos?
Also should the magnet be fitted so that it attracts the sensor or repulses?
Cheers
Speed Sensor Fitting
fsmlittler
- registered user
- Contact:
fsmlittler
- registered user
- Contact:
That looks superb but I was really interested to see anyone who'd used a more basic bracket?
Still curious about the magnet?
- jackpot
- registered user
- Contact:
when jason frost first did mine he put the magnet in the worm drive inside the hub and the cable into the hub through the existing speedo drivefsmlittler wrote:That looks superb but I was really interested to see anyone who'd used a more basic bracket?
ON MY SCOOT OR NOT AT ALL
- carlos fandango
- registered user
- Contact:
Heres mine fitted it last week. and still covered in some northern french mud
ive just put two magnets on by the disk bolts, i put a blob of loctite just to make sure they didnt fly off
fsmlittler
- registered user
- Contact:
Thanks all. Looks like I'll finally have to get a disc fitted up front. Don't suppose anyone out there has fitted one to a drum set up using a simple bracket?
Also any idea on the magnet question - attracting or repulsing?
Chris
Chris
- twenty eight
- registered user
- Contact:
I had my vapour speed sensor mounted on my disc caliper bracket,i have since fitted a mb bracket that fits on the hub spindle you then put your magnet on the hub you can fit this without a disc brake hope this helpsfsmlittler wrote:Thanks all. Looks like I'll finally have to get a disc fitted up front. Don't suppose anyone out there has fitted one to a drum set up using a simple bracket?
Chris
fsmlittler
- registered user
- Contact:
So how do I get to see the photobucket picture?
