imola piston is this right??
smoore-gt225
Main scooter: lambretta GT200
Hi just had my mate reaney round to check out the imola and see if a reedblock he had would fit but it didnt, and he thinks the piston isnt for the imola
anyone be able to help is this right or not still need a reedblock and inlet manifold
cheers in advance steve
RobD
Looks like a mugello piston.
smoore-gt225
RobD wrote:Looks like a mugello piston.
yep we have found out :oops:
but can i just cut the windows on this piston as the windows are impressed on the inside of the piston or will the little slot window on the piston mess it up if you know what i mean :?:
cheers steve
RobD
That would depend if it strays into any ports on it's travels. Can't you assemble the top end and check? If not then I would have thought you'd be safe to cut out the windows and use as is. If it does you could get the hole welded up, no need to go all the way to the bore face, just make it gas tight.
They're the same piston with different machining processes, you can see the edges of the holes on the underside.
RobD
One thing to note is that Tino's barrels and pistons might be graded like TS1's A,B,C etc. If so you might want to check yours as I'd hope that someone didn't buy that piston specifically for that barrel :shock:
smoore-gt225
RobD wrote:One thing to note is that Tino's barrels and pistons might be graded like TS1's A,B,C etc. If so you might want to check yours as I'd hope that someone didn't buy that piston specifically for that barrel :shock:
thats where i havnt got a clue but when the piston is just below the exhaust port the slot window just below the piston ring is in the ihlet port but doesnt seem to be in any other ports might go to camlam tomorrow to see what i can do
cheers steve
