Twin Spark Cylinder head
servetakid
I was looking at them today, I guess its an either or situation. You can choose where the plug is located and the other hole is plugged up ?
joespeed
not sure about this,tried it 30 plus years ago one plug used and the other soots up,can two plugs spark from one trigger head?not sure the black trigger head is already suspect for failure,team rayspeed have been using stock items for while now with failures, hope they come up with a reliable solution.
back to you! like tennis
joespeed
PRICE PLEASE!
TED CRUD
169 Euros plus p+p
Smash Ya Pastie
Washington Posse s.c
DaveTomo
Main scooter: SX 200
reading the write up on the link,if the centre plug fails just switch over to the standard plug position, as the centre plug is a pain to remove on the side of a road :? I don't think they're to be used at the same time :? :? plus an option to have a blanking plug,looks similiar to a GT head but not as good looking
giankx
It was made for using it with the central plug for better performance, if the centre one pails, you could always return back home with the standard side plug.
TED CRUD
I know its one plug or the other ,but surely some body could make it work with 2 plugs :lol:
Smash Ya Pastie
i know that it has been done running two plugs together but i cant see much point tbh
it only becomes a good idea with very large capacity cylinders as theres burn time issues
    Users browsing this forum: Semrush [Bot] and 12 guests
