Changing open mouth carb..
Timbo
To a remote air filter, a 22m GP air hose and maxi flow filter has been suggested. Been told I will loose a bit of power, is there a better alternative?
burridge01
Leave it as it is :ninja:
Brighton F.C-LOL
Lamaddict
I've given up on all those foam filters. If it's standard just leave it alone IMO
MisterD
Main scooter: Lambretta Imola GP
Timbo wrote:Been told I will loose a bit of power
I think that will depend on how much air your engine is sucking. The pod filter made no noticeable difference on the dyno, to my Mikuni TM28/Imola/Clubman setup, but I'm not expecting the same result when my JL4 goes on.
Train Driver
I think Mb did a shorty manifold, I used a 24mm mikuni on a rapido 225 and it worked very well.
Filter i think you should try a breathsweet, but still think you should get one of these
http://www.bgmproducts.co.uk/spares/cra ... m0241.html
lozmondo
The breathsweet gave my 24mm Mikuni a lean spot
Special X
Breathsweet on my Harry Barlow 230 runs exactly the same as open carb. Nice to hear from you Timbo drop me an IM mate.
lozmondo
Special X wrote:Breathsweet on my Harry Barlow 230 runs exactly the same as open carb. Nice to hear from you Timbo drop me an IM mate.
Is this on a 24mm Mikuni ?
Hi Timbo,
A 22mm is best served (IMO) on a modified/tuned/kitted motor through the use of a modified airbox and decent sstandard type filter. Yes, a foam filter can work but watch out for the silly little ones available, which actually have a very small surface area when compared to a standard shape filter!
cezeta
bgm now do a high flow standard filter.
if you go for a foam one then the breath sweet is the one or beedspeed do a k and n with short rubber that works well too.
the ribbed rubber is the killer, think about it....why spend lots of dosh gas flowing then to bolt on a convoluted inlet rubber that resticts the flow
    Users browsing this forum: Google [Bot], Semrush [Bot] and 5 guests
