vespa t5 wobble
faz49
Main scooter: vespa t5
hi my vespa t5 wobbles at low speed like it has a buckled wheel any ideas folks
ricalnic
Main scooter: Lambretta GP Monza 225
faz49 wrote:hi my vespa t5 wobbles at low speed like it has a buckled wheel any ideas folks
erm....damaged wheel :?
what about tyre pressures, mishapen tyre, hub bearings,
try putting your spare on, or swapping with rear (adjusting pressures accordingly) to see if this changes the characteristics
when did it start doing it, after a change of some sort, after winter lay up, etc ? or just gradually got worse ?
faz49
hi mate just bought it will try the spare. there is no movement when you try and wobble the wheel by hand thanks
ducksta
is engine bolt tight and rear shocker bolt?
scooter perv
Wheel rims on right way round..hub center nut done up tight? If its that bad dont ride it till you get it checked out as could be lethal.
ricalnic
faz49 wrote:hi mate just bought it will try the spare. there is no movement when you try and wobble the wheel by hand thanks
put on centre stand, and get someone to sit on rear of seat, or a plank of wood under the stand, get on your knees and spin the front wheel, looking for any signs of uneven running
freestone71
Main scooter: li150 special with ts1225
if its a mk1 t5 make sure the headset isnt slightly moving as they can come loose
gimp1971
Dont ride it slow then :lol: :lol:
Juan
Presuming all the above are in order look at the rear suspension and if that's in order and the frame isn't bent then most likely the engine mount bushes are shot.
ricalnic
Faz, you get this sorted ?
