Kickstart pinch bolts.
Ihateyoubutler
Anyone know where I can get some proper high tensile kickstart bolts (c/w nuts) from? Stainless ones might as well be made of cheese.
Thanks.
Supereibar
Hello, the main problem is that pinchbolts are M7. What I would do is I would try at an industrial hardware store. Take your lever with you so you can test the length with a vernier caliper. Ask the clerk which surely will be very helpful and show you the different variety. Here in town we have one which has a huge catalogue. The problem is that these bolts are mostly made with an allen head.
Kind regards,
J.
warts
Main scooter: honda
http://www.boltmeup.com/m7-x-50-hex-hea ... 2421-p.asp
Just a specimen size, they have other lengths if this not suitable
is there not a fastener supplier near to you ?? also many drill out to m8
camel
websters sandycroft or drb deeside industrial park
I'm very suspicious of stainless fasteners after shearing one of the rear hub bearing retaining plate ones recently with the torque wrench set at 5NM...
Loads on eBay ;)
    Users browsing this forum: Semrush [Bot] and 18 guests
