If I were to do that, the fuel tap will be even more in the way of the engine mount. :freak:rosscla wrote:Can you undo the straps rotate it a little anti clockwise?
The thread on the tank does look long tho'...
Its not a ssp tank or a tsr tank.
servetakid wrote:Me again.
Right long range tank fitted, but the petrol tap doesn't clear the engine mount.... I've seen others have had this problem, some have cured it with a reverse exit tap, by filling the threaded part of the tank... Here's a photo what do you think I need to do?
It's worth a go, before resorting to a hammer!nelson pk wrote:Yes, corrado is right, all ours were Saigon Scooter centre tanks. The fitting for the tap is rubbish. I did say the hammer thing was the official bodgers way and do so at your own risk! However i have TS1 cones fitted as i run a Monza and it made no difference. I cant see how shortening the thread would have made a huge difference as its the position at where the tap comes out of the tank not the length of the thread thats the problem. If you shorten the thread the tap will still bash the mount when you go over a big bump as your shock compresses.
I could be wrong and i hope you dont have to resort to the bashing trick.
Good luck!
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 2 guests
