GP wont start when hot?
lockman69
:oops: :cry: :?:
200 Sil Stage 4, JL3 and Mikuni 24
Scooter starts 2nd kick every time from cold but once its warmed up it just doesn’t want to know.
Any ideas ?
Cheers Guys
camel
had this with a 22mm delly....was the needle valve worn
ArmandTanzarian
I'm sure someone far cleverer than me will know but have you tried a smaller pilot jet? Also are you using a remote filter? Sometimes fumes accumulate in the elbow when you stop and make it too rich to start. A suggested remedy is to turn off the fuel 100 yards before you stop and to make a small hole at the lowest point of the elbow to let the excess drip out when standing.
could be for a number of different reasons...
  • blocked petrol breather cap ?
    wrong plug heat rating ?
    plug gap ?
    CDI ?
    choke not closing ?
    pilot jet too big ?
    float needle worn ?
    worn rings ?
    crank seals ?
has it suddenly started misbehaving, or has it been getting gradually worse ?
does it go ok once it does start ?
lockman69
Cheers for the input Guys
It’s a new engine with new AF crank, bearings and seals. The carb, Cdi (Ducati) are all new also.
The scooter was recently set up on a Dyno, I should take it back to the tuner but I don’t want the hassle or to be with out the scooter as he does nothing in a rush and its time of work to get it there.
When the scoot is running it goes well with no obvious issues, but I will go through all your points and see how I get on.
Thanks again
you,ve got an air filter on have,nt you............? :D
lockman69
I have indeed...........bellows connected to the air box/filter..........................is this the problem ?
lockman69 wrote:I have indeed...........bellows connected to the air box/filter..........................is this the problem ?
be worth trying without...
I had a 22mm carb [albeit a jetex] that would only easily start when warm without the air hose connected... I ended up changing the jetting to suit riding it without
what you need is ,..........a small 1mm hole in lowest point of bellows/filter...........
to drain off excess fuel..............
lockman69
Excellent.........shall give it a go.
Cheers guys
Brett (aka lockman69)
