sito or sito plus
woody
I need a new p2 exhaust and am fancying something more standard and have been offered a sito exhaust , now i,ve been told to only use a sito plus so my question is how do i tell the difference ?
nicsar
Main scooter: fast smallies
Dont waste your money. Get a sip road. A couple of tenners more but well worth it.
freestone71
Main scooter: li150 special with ts1225
youll find a sito plus a lot louder than standard if that makes a difference to you
goldeneye
sito plus are good pipes, bit loud after a while , but better than standard. the new SIP road pipes are good , ive only fitted one, but the lad was well pleased at whitby with it. i used to run original piaggio standard exhausts on my P200"s , and honestly, i thought they were great for a standard style pipe. i was always 2"s up, and needed spare wheel, cable access, ground clearance etc. if i was to get another P200 pipe new (heaven forbid! nothing is new in my world!) it would be the SIP road thing, as ive spoken to another couple of people who use them, and they were pleased as well, more mid-range pull, and a few more revs. ideal for a P2 really.
woody
Thing its not for a p2 lads its for a ss180 with a p2 barrel stub ( trying to get a few more mph out of it as nobody does a kit for them ) i,ve tried a left hand exit sip pipe ( not a road pipe) and not keen as it didn,t do owt for it , was a bit boggy , then i tried a simonini for the trip to whitby and that was ok but the end can hit the panel and smashed it up cos of clearance over the bumpy roads ( you may have seen a red an white gs with one panel at whitby ? well thats the reason) so thats got to go before i get another panel , so have recommended to get a sito plus but will try owt so long as it will do the job
nicsar
Im gathering parts for a SS180 tune up at the moment.
Got a GS P stub also. Im gonna stick a sip road on it. Together wit p200 piston and conservative porting it should be nice.
woody
nicsar wrote:Im gathering parts for a SS180 tune up at the moment.
Nice one keep me informed on this mate if you don,t mind , who,s doing the work for you ?
    Users browsing this forum: Amazon [Bot] and 1 guest
