rear brake light
gpsteve
i have just done the lights on my lambretta cut down all the lights are working but can not get brake light to work its got a front brake light wire ,and rear foot brake light wire can any body help
dodge
noob
Main scooter: lambretta
try disconnecting front wire then put 12 volt tester on connector on foot brake to make shore you have voltage if so check switch
gpsteve
thanks for the help dodge problem sorted it was front brake wires the lad that i got it of used heat shrink to cover the both wires so both the wires were touching each other :biggrin:
