Slipping Clutch???
shureimage
Main scooter: SIL GP200
I've got a bit of problem,
just fitted a rapido 225 top end running a 30mm & jl3, standard gp200 gearing & 4 plate surflex clutch, took It out yesterday seems like its got great pull until 4th gear, pulls up until about about 6000rpm then speed seems to tail off but revs carry on doesn't seem to be in lower gears but could well be, clutch was fine with the 200 top end on ??
storkfoot
Sounds like it. Try it in a lower gear, lots of revs, and going up hill. This will find it out.
A slipping front sprocket can also replicate the feel of a slipping clutch.
goldeneye
its too low geared, my rapido 225 classic /30mm /48 clubman hit a brickwall at 65mph with GP200 18/47/5.2 gearing. changed to 19/46 GP200 box 4.8 ratio and it flew . you can still use your 82 link chain with this set up, just a sprocket change. great touring set up.
shureimage
My only reservation with it being the gearing is that the max revs peaked @ 8100rpm, & if I'm reading the charts right standard GP200 gearing set up would put me @ appx 80mph @ those revs.
I topped out @ 66mph.....
Cheers Dom.....
goldeneye
you"ve just answered your own question ....... by 1 mph
Also not following that...why would upping the final gearing improve this?
5.2 should be easier to pull than 4.8...
goldeneye
just my experiance with my Rapido , wouldnt pull over 65 on 5.2, pulled really strongly, but wouldnt go any faster, upped it to 4.8, and all was well.
wack 63
Main scooter: '71 GP TS1
Why not go half way,19 x 47 with slack 82 link ? 4.8 is fine on a calm day and no hills and Rapido's are not known for their torque as standard.
shureimage
Cheers for the replies got some springs on order, so will get that sorted & then have a look at the gearing.
It's also not a standard rapido it's had a fast road tune & ports match by chalkie white
Cheers again, Dom.
shureimage
mmmm think I might order a 19 tooth as well @ least I could make some comparison's
Cheers Dom.
    Users browsing this forum: Google [Bot], Majestic-12 [Bot], Semrush [Bot] and 12 guests
