Scomadi radiator and fan issues
red
Strange as I've only just uploaded them to Photobucket :?
red
I'll try again tomorrow morning
red
Having another go at posting the pics :?: :?:
Finally got round to fitting spacers of approx 5mm(I used anti vibration washers that usually go between the underside of Lambretta legshields and the struts)also used some between the housing and the frame.
Has a steady ;) ride to Whitby and back yesterday and it seems OK,fan only came on once so hopefully the improved airflow may be helping.
Only time will tell,I'll keep ya updated.
How it was before I started:
with spacers between fan and rad and also between housing and frame
Before all bolts fitted and it was finally fixed into place just showing the gaps
I was told by the owner of Scomadi No.14 who I saw at Whitby that Frank has now put spacers between the rad and the fan on his so there may be a problem with running and temperature issues without the spacers.
iang
Main scooter: GP-auto / gts 250
I'm no expert but it has always surprised me that the rads are fitted like this as surely radiators work best with air flowing through them rather than across them !..I know of guys running watercooled auto's in lambretta frames with the rads mounted underneath and on their backs :!: :!: ...and all the ones i know have cooling issues...I know they are ltd for space and obviously there are cosmetic reasons but surely there must be another way :?:
The dac tec set up dosen't look to bad (2 rads long ways in a v shape)and i'm sure you could add two nice small fans to the rads for increased cooling... food for thought maybe :idea:
red
Cheers for that Ian.
I know someone who can make me radiators of any size and also pressurised so i won't need a fan.
It's something to think about for the future.
Gunny
I sent my radiator with the fan connected to my RD350 to GMX down south who spec race moto-cross and they said no matter how much air was getting through the fan used (gts300) it would run very hot as the core was cheap crap and couldn't handle the heat , they also commented on the fact that it wasnt pressurised and meaning it pisses out everywhere once it's getting just a wee bit over heated..
In saying that i was running an RD350 of a gts300 rad,but techology has moved on and with the right material a radiator half the size of the old RD ones should do the job.
The cooling system is totally sorted now and i'd recommend them to anyone..
