malossi 210 wont go over 55
Danger
Main scooter: lambretta TV200
thanks very much for that ian , all help is greatly recieved ,
Danger
told been to by the fella i rebuilt this engine for that its meant to already have a t5 4th fitted
Bofs
If it ran well with the PM then I`d try that on it again for comparison.
Both the PM and the SIP make peak power between 6500 and 7500 so shouldn`t be that different.
The fact it won`t rev out even in 3rd never mind 4th seems odd.
Muffspeed....no muff too tuff
Bad Samaritans SC
1957 Zundapp Betta 500 Auto
Danger
the pm is gone , its your old engine ivan bought off you years ago bofs , i really dont understand why it wont rev out in 3rd either
is your throttle working ok ,is it fully opening the carb slide when wound back fully
Danger
yeah sean pretty sure it is on idle to full open it will rev out quite cleanly
bazman
Try a different stator could be electrical and lt coil breaking down under load, relatively easy and quick to change over. Also does it tickover and idle ok?
Danger
bazman yeah scooter ticksover an idles ok plus scooter starts bang on one or two kicks
bazman
Ok not oil seals then , when it revs out in 3rd does it tend to feel sluggish/not revving out or missing?
Danger
its not missing , it flies through 1st an 2nd with ease once you put it into 3rd its feels tight with the more throttle you give it the tighter it gets , its like slamming your foot on the back brake an trying to open the throttle wont go anywhere
