Anyone else find Smiffy's posts hard to read while bouncing up and down in the chair?RinB wrote:The reason being that as the exhaust cracks opens the initial blow down doesnt go out of the port straight but at an angle of say 40-60deg then as the port opens it straightens towards the 10-15deg.
So to help that first pulse flow without hitting the opposing exh pipe side wall the ports are angled.
I believe this is the one major thing Terry shepherd wished he had done with the TS1 barrel
Smiffy
RB20 (200cc) - Pictures and Spec
- corrado
- Dealer
- Main scooter: Lambretta GP
yes he did say so in the scootering interveiwRinB wrote:The reason being that as the exhaust cracks opens the initial blow down doesnt go out of the port straight but at an angle of say 40-60deg then as the port opens it straightens towards the 10-15deg.
Smiffy
Powolotti wrote:brilliant documentation Dan![]()
this boostport thing...dunnoCan we expect Airsal to have a flowbench where they test prototype cylinders? Or is it just a "here´s too small, add something here" approach?
Yes, they have a flowbench, you can truste me.
fishi
- jason frost
- Dealer
Here you goRinB wrote: As for the manifold definately weld it up and reshape without any hesitation ,Ill put some pics on here later. But I think Jason has already shown this.on old forum![]()
you've got my attention Smithy, having a look and a good report on the rb25 is what im waiting for.RinB wrote:Dan good report m8
Definately intreged about the 3 three finger boost port I believe the rb250 has the same port but still keeps the bridge
Exhaust ports.
Watch this space as I will hopefully have one on the table next weekend, & Ill do a report on the RB250 as you have done Dan.![]()
Word of WARNINING if stroking the RB's watch the boost port fingers ,as the bottom ring can catch under the finger in the port. Make sure you check this
Also I will show what I have done to a RB225 once its finnished, you have seen some photo's but they are I can asure you work un-finnished![]()
Smiffy
- Bofs
- Main scooter: Zundapp Betta 500
Looks and sounds amazing. What about the wall thickness on the spigot taken to 66mm, must be well-thin?
Muffspeed....no muff too tuff
Bad Samaritans SC
1957 Zundapp Betta 500 Auto
Bad Samaritans SC
i fink its about £390 retail ?????? this one i got today but i am a dealer for af soBofs wrote:Looks and sounds amazing. What about the wall thickness on the spigot taken to 66mm, must be well-thin?
whats ther in the full kit
you get all whats ther in the kit nice one
- Information
Who is online
Users browsing this forum: Google [Bot], Majestic-12 [Bot], Semrush [Bot] and 31 guests
