Have a cookiesoosh wrote:It's fitted now......and I still cut the lawn.
How does it run?
Ok the new graph is clearer but I still think there's a problem with the ranges and curves...anyone agree / disagree?rosscla wrote:Am I missing something here?
If I've followed the discussion correctly then the this only seems to work to vary the degree of advance and you won't get back to your 'base' setting till it reaches 12.5k rpm? How many scoots rev out that far?
I'd have thought you'd want some degree of retard at high revs?
Surely it would be better if it went a bit on either side of your '0' point, , say with that set to 18 degrees if it went to 24 at 3.5k rpm and back to 18 at say 5000 then on to 16 beyond that?
dont understand graph were is stage 4,5,6 and 7 ? i can c 0-3 also it shows it returning to normal timing at 12500 rpm ? when u need it to do this surely at around 6000 rpm ?rosscla wrote:Ok the new graph is clearer but I still think there's a problem with the ranges and curves...anyone agree / disagree?rosscla wrote:Am I missing something here?
Users browsing this forum: Baidu [Spider], Google [Bot], Semrush [Bot] and 5 guests
