210 spaco 28 mil jetting
Danger
Main scooter: lambretta TV200
malossi 210 , casings matched to suit kit , malossi head , s.i.p evo jl lefthander pipe , 28 mil spaco carb delly copy what jetting should i be running , so far its got
slide 40
x7 neddle
main 130
choke jet 45
atomiser av268
idle jet 50
float needle valve 200
goldeneye
mine was..AV264, X7 second clip from top, 55 pilot, 70 choke, 40 slide, main 132 mixture two turns out, 17 degrees timing. running a malossi rubber to the frame, no filter. still going well now. that was on a 30mm dellorto, JL righthand.
