Anyway it is now sorted and the problem was a blocked radiator and an inoperative fan.
As you can see from the pictures the radiator and fan are inside the housing fitted horizontally under the legshields.
When i bought the Scomadi it wasn't fitted with any form of protection at the front of the housing to protect the fan and rad from anything thrown up from the front wheel so I put the mesh on and then changed it to the metal grille.
I'd done approx 9000 miles when it packed up and the reason why it died was due to the fan and radiator being f**ked so it wouldn't cool down whicj in turn blew the head gasket and it was also found that the inlet manifold was split.
As you can see from the pictures the fan is covered in crap that's come off the road and where the fan is fitted it's forced everything into the radiator and flattened all the fins so in effect I've had less than half a radiator working.
The underside of the radiator is fairly clean and clear but I've been told that I should have cleaned the rad and the fan so this wouldn't have happened,as the fan sits on top of the radiator and the fan housing is just about touching the underside of the frame this is going to be difficult unless i drain the system and remove the radiator and fan and clean them,I suppose I could always use a power wash to force through the bottom of the radiator and clear it like that,I'll have to give it a go.
I've been speaking to a couple of mates to see what ideas we could come up with and we were wondering if i could put spacers between the frame and the hosing and also the fan and the radiator so if any crap gets through the fan it has a means of escape out of the bottom of the housing.
Another option was to blank off the front of the housing and put some scoops on the side and protect them with a Goretex like membrane that wouldn't affect the air flow but stop the water getting through.
Another mate was in the process of getting a front hugger made for his Scomadi but as he's sold it that's not happening
Would this work?
Any other options without moving the position of the fan and radiator?
View of housing from underneath
From front with metal grill in place
Old fan and radiator view from top
Showing fan position and damage
Close up of damage
Showing dirt etc on left hand side of fan
underside of radiator
View from rear of housing showing fan on radiator and lack of room to work and clean between fan,radiator and frame
Split on inlet manifold
Another view of split on inlet manifold
