Hi anyone know what type of aluminium is needed for a weld on cylinder packer and half liner as im looking to do a long stroke ts1.
cheers
welding a ts1
pro-circuit
- registered user
- Main scooter: lambretta ts1
- Contact:
- Terrible Taff
- Dealer
- Main scooter: Lambretta's & Vespa's
- Location: 21 Meyricks, Coed Eva, Cwmbran, Torfaen, NP44 6TU
- Contact:
In the past I have used rods with 17% silicon content when puting in half liners & extending the gasket faces, but to be sure have a word with Langcourts in Weston Super Mare as the repair damaged alloy cylinders proir to replating.pro-circuit wrote:Hi anyone know what type of aluminium is needed for a weld on cylinder packer and half liner as im looking to do a long stroke ts1.
cheers
Tel: 01934 612226
Ian Frankland
Taffspeed
07794 003276
pro-circuit
- registered user
- Contact:
Thanks for the reply Ian, would I need to buy a particular grade aluminium to make the packer and liner from as I was thinking of removing top of barrel above exhaust port and make wider fins with extra length for the stroke.
cheers
cheers
