Super Monza, is this what we've been waiting for?
Agree great picture bet you enjoyed that , looks like your hanging on :lol:
just wants clearing for bsso use :D
brmspeedwell
what was the final price for the full package ? what is included in the kit as to what else would you need to build to get the spec on the dyno?
You do need to hang on to this and treat it with respect or you'll soon find yourself in trouble, it'll pull away in first and power wheelie no problem but once over the initial burst, from 5-8k it'll just keep pullng in any gear, but the gearing is so tall that you seem to just keep going in the same gear, and then realise you have another, and another, even 1st seems to last for ages, and as long as you're anything over about 4.5k rpm it'll just pull effortlessly and still feel like it'll power wheelie if you let the clutch go and put the power down too quick! Of course there are options if you want more but the one on the dyno is nothing different to what you can buy off the shelf.
You won't get a lot of change from £2.5k for the cylinder, head, reed assy, pipe, bearings, seals, VHSH30 carb, crank, Varitronic ignition, PT pipe, together with crankcase matching and mag housing mod, but this is the top spec and as has been said, it's pretty much plug and play. If you have the money, you won't be disappointed :-D
Special X
RICSPEED wrote:just wants clearing for bsso use :D
Street class or group 6?
nelson pk
Nice pic soulsurfer and sounds like it does what it says on the tin!
Did you put you order one?
well being reed makes it no good for group 4 so yes ;)
al-super3
That sounds good to me will get on the phone for test ride and see for my self :-)
I am here: http://tapatalk.com/map.php?b0h1gd
Scream at me until my ears bleed
sideout
soulsurfer wrote:......You won't get a lot of change from £2.5k for the cylinder, head, reed assy, pipe, bearings, seals, VHSH30 carb, crank, Varitronic ignition, PT pipe, together with crankcase matching and mag housing mod, but this is the top spec and as has been said, it's pretty much plug and play. If you have the money, you won't be disappointed :-D
Mike, great to get some independent feedback on both this kit and the TT3. Did you also ride a TT3 kitted scooter, or did I dream it? Maybe Scootering will do a comparison feature?
However, http://www.supermonza.co.uk/about.php has got a couple of buttons which helpfully populate your CamLam shopping cart for the bits you need to buy. When I did it the total was over £3k for the cooking version, the factory was £4.5k!
I actually thought the Avanti was what I was waiting for (and before that the RT220 :roll: ) but the reports of having to fit a reed valve to cure the spit back has put me off a bit :cry:
The nearest I'll get to affording the Super Monza is probably one of the T shirts :D :D :D
jonashford
soulsurfer wrote:Yesterday, I was doing this...
...and today we have this from CamLam Facebook page
Hi Im curious what speeds you achieved on the scoot mate? cheers
