LAMBRETTA stator readings
no-hair
i need to check a electronic stator out , does anyone have the readings for checking the coils and pick up in ohms , cheers :fb:
no-hair wrote:i need to check a electronic stator out , does anyone have the readings for checking the coils and pick up in ohms , cheers :fb:
Ok, here goes:
Pickup - White and red = 95 - 115 ohms
Low Tension - White and green = 450 - 500 ohms
Lighting coils - White - yellow = around 1 ohm
