FOXHAT 260's
niz
Main scooter: Sx200...Iataljet Dragster
Rang and spoke to Alan today, planning on getting the RB260 monster built by them. They were very helpful over the phone, gave me some great advice. ;) Will let you no how it goes.
tj hooker
Main scooter: jet 200
dont standard rb250s produce that much power ?. my friends rb225 with just matched casings did 26bhp at diablos
TS1-200
We all know that you can`t compare power outputs from different dyno`s. Also I spoke to Arthur at length last year while he was giving me a lift to Calais from Amiens after my scoot spat its plug out and stripped the thread, never met him before that, full time he is a motor technician I believe, but his knowledge of Lambretta engines and the tuning of them is mind blowing, most of which went straight over my head ! We were in a van following his son and his mate both riding Lammies with big TS1`s and we couldn`t keep up with them, only when they stopped for a break or fuel.
Keep on keepin on
tj hooker
seems like a lot of work and expense to end up with same bhp as bolting the standard kit on
Which standard kit does 85 in 3rd gear?
Special X
Any sccoter on TV200 gearing with an engine that revs to 9,600rpm. Conversely it won't pull in third from less tham 48/50 mph. It's geared to do nearly 110mph in top so I reckon it won't pull 4th. With GP200 gears and 19/47 It would pull (possibly acheivable on the road but not sure) 75 mph in third with useful power from 45 mph, and a theoretical 98mph in top. With std GP200 gearing it would do slightly over 70 mph in 3rd and an acheivable 92/93 top speed.
About what a well built RB250 would do I think
TS1-200
I think all this talk about 85 in 3rd possible 98 in 4th is all academic ,I think anything over 80 on what is basically a 50yr. old commuter bike is fuxxing scary, I do like to ride my TS1 quickly, but at these sort of speeds I tend to think....what if ? I think its all about good acceleration and generally comfortably quick cruising speeds.
Keep on keepin on
TS1-200 wrote:I think all this talk about 85 in 3rd possible 98 in 4th is all academic ,I think anything over 80 on what is basically a 50yr. old commuter bike is fuxxing scary, I do like to ride my TS1 quickly, but at these sort of speeds I tend to think....what if ? I think its all about good acceleration and generally comfortably quick cruising speeds.
I agree 100 %, lammys at high speed sets the brain thinking..:-o
Sent from my GT-I9000 using Tapatalk
tj hooker
what goods 85mph in 3rd gear. unless this street racer only street races on the m6. sureley its how fast you can get to it which i cant see it being eye popping
willwander
I'll agree with that, full bodied lammy's can go into a s**t yourself speed wobble with the slightest bump or cross wind once your approaching 90, where your weight is on the bike also makes a big difference. There's no way I would ride mine at anywhere near that on the road.
I've tried a few things to try make mine more stable including stiffer rear shock and engine mounts but it is still a problem might have to try a steering damper next. If anyone has any other ideas about improving straight line stability I'd like to hear from you.
standing mile: 118.6mph
