speedhut gps speedo
wax
Is there anyone on here with a CNC/ lathe who can make me a ring for my headset please.........?
WINTERMODEL150
Looks nice Mark :D
Dean
Knowledge
It looks very tidy Mark. All you need is the snow to melt, and then you'll find out if it works. :D
It will work Martin. Have faith
wax
Where are you sticking the magnetic sender mark?
Under the horn cast initially
sydduckett
WINTERMODEL150 wrote:
Looks nice Mark :D
Dean
Like the levers Mark, whats the story with them?
ta
Not my bike sef but it is fully hydraulic
Update on this setup.
It seems to pick up satellites perfectly, I have fitted the sensor under horncast and wired the hot start connection into the loom before ignition so it gets a permanent feed to track satellites , turn ignition on and it runs thru the speedo start up procedure( 20-30seconds) and is ready to go by time you started bike. Hopefully road test next week :)
