Legshield question?
muffster
Xbox live gamer tag: muffinator233
Main scooter: LI 125 S3
Hello.
I need some legshields for my SX 150. But i don't know the difference between chrome ring & none chrome ring.
My LI is a chrome ring, but the frame on my Sx where the forks pass through, is different where the forks would meet the headset.
Does this mean that i need different legshields to those on my Li, and whats the difference?
Many thanks.
any li type will fit ..i think the ring type flare out slighty at the head stock end ..stickies book shows the differences
muffster
Had a look and it does seem like any will fit. So i may be barking up the wrong tree.
I'm not sure how the headset/legshield/forks fit together on the frame. The difference on the SX frame is referred to in the book as a steering race so what exactly do i do with it?
Many thanks.
ill have to dig my book out to tell you which page to look at
There shouldn't be any fitting issue with the legshields. The chrome ring houses the top bearing race for the forks and it's imperative the correct headset is fitted, this will be obvious if there's an issue.
Hope this helps.
stikies book .page 145 ...middle left two pics show the difference
but as said either will fit
