Eating Plugs
Bilko
Main scooter: LI150
What would cause this?
Second plug in a fortnight
Pissed off, from Belfast
Bilko's Oily Blog
whats the colour like ? what sort of plug?
mine was eating them before the piston shrunk and it siezed due to running a b9 with 17 .5 degree timing and rich as fook on idle to 1/2 throttle , hopefully be fixed when/if i ever get it back
richie
Hi there,
Plug gap and temp can be critical on a tuned motor, On my tuned 225 Rapido, ignition set at 17' i run a Champion N3c with the gap set at 0.5mm.
What is actually happening to the plugs? any pictures.
Cheers.
Ian
Bilko
Main scooter: LI150
. Edit
Bilko's Oily Blog
Bilko
Main scooter: LI150
I wrote the post on the move so didn't post much detail, but the plug is NGK B9ES gap is .5. Plug looks great. Dark coloured. I've gone through a new B9ES and an old B8ES Not from the same place. One English one from Northern Ireland.
Bilko's Oily Blog
dapper
Rob, there's been a spate of counterfeit NGK plugs about. I'd change to Nippon Denso from MB if I were you
Bilko
Main scooter: LI150
I was thinking of trying another make, but I'll see if it's not another issue.
Thanks for the info.
Bilko's Oily Blog
Monty
The Nippon Denso Iridium in my Muggy is into its 3rd Year (about 2.5K per year)and 2 years on the Imola, (Same sort of mileage so nothing compared with some) I have never had to change them and rarely carry a spare, I was always changing the NGK ones
joey
...try champion N3C....can't remember when i last changed it...?
Bilko
Main scooter: LI150
Thanks for the info lads.
Bilko's Oily Blog
