right ok,
i have a pk100 that i need to get running so i can get rid of it,
bloody thing won't start unless you bump it and only then it works on the 5th or 6th time of bump starting,
then runs for about 10 yards then dies,
so i have -
checked the tank, no rust and no bits inside,
checked the fuel tap, no blockages and lets fuel flow out perfectly fine,
took the carb off, cleaned it all out, no signs of bits or filings blocking any of the carb up,
needle is fine, float is fine, etc etc, nout wrong with it,
so i checked the spark plug, nice chocolate brown, and has a decent spark when kicked over,
put it all back together and still won't start,
i think there is a clutch problem however as when in gear and the clutch is pulled in when not running, it feels like its still in gear, although i think its clutch drag, so going to have to take it out and have a look,
took the head off, piston is fine, a bit of coke build up on the head, cleaned that away,
seems to be a nice browny ring at the top of the cylinder though, does this indicate possibly it needs new piston rings?
any ideas of what next to try?
anyone know exactly what jets a pk 100 should have and how many turns the air mixture screw needs to be turned?
cheers
vespa pk, doing my head in
- Main scooter: street racer px
it could be the rings, as theres a nice brown ring at the top of the cylinder,coaster wrote:What's the compression feel like, could be gummed up rings if its been stood for a while. Is the choke working ok, it's pretty cold at the moment so will probably struggle without it.
yer compression seems a bit easy to be fair when kicking it over tbh
MCH wrote:it could be the rings, as theres a nice brown ring at the top of the cylinder,coaster wrote:What's the compression feel like, could be gummed up rings if its been stood for a while. Is the choke working ok, it's pretty cold at the moment so will probably struggle without it.
its defo getting fuel as iv tested it without the head off with choke and throttle on, and there is fuel getting through
It could be that the piston is in the wrong way?? very easy to do on a smallie.....so I'm told!
