ts1 230 gearing
joespeed
golf19gt wrote:i have a ts1 230 with 34mm carb jl3 exhaust it has a pacemaker box with 16x47 can it handle going to a 18 front sprocket and will it pull this gearing ok
if your riding it regular then you will know if it can take an extra tooth on the front sprocket or not,
i have a 25hp tsi broadhurst tune running gp indian gears and drive train it has to be doing 62ish to excellerat in top if your doing 59mph you have to gear down it will run at 80 for long periods,and if its windy your in third!
so mine doesnt like the set up at all and definatly cant pull a 19 tooth front,jl4 34mm dellorto!
    Users browsing this forum: Google [Bot] and 11 guests
