suzuki 190
handofdave
Main scooter: li ts1
building a 190 and need to level up my port timings ,was going to fit a 115 rod will this work?also been told to get an rd400 rod is there any specific year or are they all the same?
any info appreciated
ps using an sr alloy barrel
cheers
dave
Stokie
The TV or RD400 con rod can be used with appropriate packers / gaskets.
You may need to have your crank webs machined to use the RD400 rod as I think it's wider at the big end than a standard Lambretta rod.
If you need someone to do the work for you then Harry Barlow of ProPorting in Leicester (tel: 0116 287 1285) is well known for crank rebuilds as well as the other tuning required for these conversions all at very reasonable rates.
Knowledge
It is worth opting for the longer reach conrod, as it gives much better options for the inlet timing, which can be seriously compromised by a standard-length rod.
The Tv rod will handle the power that nearly all 190 conversions will deliver. As it is a straight fit, it is cheaper.
Martin
Beanhead
Main scooter: 1970 Lambretta gp
Harry has done a crank for me, very good work, i'd recommend him.
Facebook - Lee Bardsley
Vesperados S.C
Sent from my PC using My Fingers
