lambretta gearing
golf19gt
Main scooter: lambretta ts1 230
i have a ts1 230 the gearing is a standard pacemaker box with 15 front and 46 back sprockets would it be worth changing the front to a 16 or 17 tooth if so what would i gain or loose by doing this
It depends on what pipe you are using but I would have thought it is revving it's nuts off .Have a look here http://www.scooterhelp.com/tuning/lam.gear.calc.html or the gearing calculator link on this site. If your scoot revs to 8000 you should in theory get 80 ish with a 17 tooth sprocket but then get into 1/2 link chains or a push down tensioner with an 82 link chain.
golf19gt
its got a jl3 and a 34mm dellorto carb
17x46 (4.98:1) will be fine with an 81 link chain, but if you want something a bit taller 18x47 (4.8:1) with an 82 link should be okay too.
phil23fair
Main scooter: Lambretta Li 250 Special
I've got an iron lined TS1 230 tuned by Harry Barlow. I run with a SSC Taffy copy exhaust, 30mm phbh carb, pacemaker gearbox with 47/19 sprockets and it pulls like a train.
I would definitely raise your gearing but would consider what I did and buy a top down chain guide and a good 82 link chain so you can experiment with the 46 tooth rear sprocket and 17 and 18 tooth front sprockets. if 18 is too tall you've still got the option of changing the rear sprocket to 47 and not buy another chain.
golf19gt
ok thanks for advice
phil23fair wrote:I've got an iron lined TS1 230 tuned by Harry Barlow. I run with a SSC Taffy copy exhaust, 30mm phbh carb, pacemaker gearbox with 47/19 sprockets and it pulls like a train.
Good advice ;)
golf19gt
took casing off today and its running 16x 47 going to buy an 18 tooth front sprocket will this work ok and pull 4th gear
    Users browsing this forum: Majestic-12 [Bot] and 93 guests
