Lambretta revving on after clutch is pulled in.
Chris F
Main scooter: 1967 Lambitsa 200
Question for you. I've got a 24 mil Mikuni on a 200 Sil barrel with a taftspeed mk4. The prob is when pulling in the clutch it's revving on for about 2 to 6 seconds before it drops down enough to shift appropriately. It's not revving it's nuts off like it has an air leak & it doesn't do it all the time, but its enough to be annoying.
Any thoughts / ideas?
Thanks in advance.
Chris F wrote:Question for you. I've got a 24 mil Mikuni on a 200 Sil barrel with a taftspeed mk4. The prob is when pulling in the clutch it's revving on for about 2 to 6 seconds before it drops down enough to shift appropriately. It's not revving it's nuts off like it has an air leak & it doesn't do it all the time, but its enough to be annoying.
Thanks in advance.
Throttle cable routing or fraying ? Pilot Jet ??
Air leak ?
Sent from my GT-I9000 using Tapatalk
Darrell Taylor
Main scooter: LAMBRETTA
it might be the clutch isnt disengaging fully/dragging holding up the revs
also piston port motors at high rpm have a habit of holding the slide if the slightest bit tight
u could try richening the mixture screw a turn or a slightly bigger pilot jet just in case its high rpm/small throttle position leaning out.
Muppet
Darrell Taylor wrote:it might be the clutch isnt disengaging fully/dragging holding up the revs
would a retro fit power jet help in this situation?
muppet,
C’est la vie
johnd
Main scooter: 1970 Dl125
My clutch used to do this, it can give you heart failure after a long blat at full throttle!! To make sure that it isn't an air leak or lean part throttle and that it is the clutch, try knocking it in to neutral and see if the revs drop straight away.
red ghost
Main scooter: lambretta gp150
muppet,
still yet to see a pj on a 24..
and i'd say the carb is lean..
Darrell Taylor
muppet,
the power jet will only draw at wide open throttle or a bit less depending on its fitted location in the venturi so wouldnt help apart from improved slide lubrication if its sticking
Darrell Taylor
muppet,
the pwk is available as a 24mm and 21mm power jet version from the various pwk copy manufacturers although the power jets function is different on most of them as its fitment method varies considerably, some deliver early and some dont deliver until the throttles been open a few seconds
