Kick start position ????
mick1
Main scooter: Li Avanti 225
I got a p2 lump in bits...i asked a mate to put it together as i was busy....a couple of years later i've decided to put the engine in a spare frame i had. The engines in, everything's connected and i've come to put the kickstart on...the kickstart is angling downwards and there's not enough gap between the kick start and the floor to even get a decent kick ???? As far as i'm aware (please correct me if i'm wrong) the kick start shaft can't be put in incorrectly... this leaves me thinking it may be a rally shaft and they are different ?? It's a bit of a job to drop the engine and split the cases if the problem could be solved with a different kickstart.....any replies (usefull ones !!) gratefully recieved.
Juan
Try a Rally or T5 kickstart, the splines are in different position to the PX ones.
mick1
Juan wrote:Try a Rally or T5 kickstart, the splines are in different position to the PX ones.
50 years old..had a scooter since i was 16 (rally 200)........and still learning !!! Thanks
ducksta
check splines mick could have rounded off on the kick start
goldeneye
might be wrong quadrant/lever fitted. i put a 150 super lever on a PX shaft and it was pushing the panel off! probly summat simple.
mick1
ducksta wrote:check splines mick could have rounded off on the kick start
Splines ok...it's more of a shaft alignment problem, which i don't think can happen (or wrong quadrant !!)
paulski
yeah deffo got a rally type quadrant in there bud,ive just built a p2 lump for my sprint and i changed the quadrant to maintain the curly kickstart,the splines are a bit further clockwise than the px type quadrant,so it will point to the floor like yours,you'll just have to fit a curly type kickstart lever to overcome the problem unless you fancy splitting the casings to change the quad...
mick1
Rally kick start on order...cheers lads should make it a quick fix !!
mick1
Just got a rally style kick start.....perfect !! This forum has saved me a lot of time and hassle, all advice much appreciated.
    Users browsing this forum: Amazon [Bot] and 1 guest
