Italian S2 legshields ... same as Eibar S2 ??
soullad
Ok, aside from the front mudguard fixing holes how do Eibar S2 legshields differ to Italian S2 legshields. I'm trying to get to the bottom of any specific PROFILE differences, if any.
Wideys are becoming increasingly popular and so the value of a decent set of Italian leggies continues to rise ? Horncast brackets aside do s1 and s2 differ too?
Are the remades based on API versions too?
There are always more questions than answers....
Cheers
Supereibar
Hello pal, yes, they are different in hole position, as the early Spanish SII's differ a tad in hole possition from the late ones.
Best,
J.
lambytone
You may find that they are slightly longer as well. I bought a pair for a series 1 project and have had to weld up and reposition the runner holes. Then when trying a dry build with panels, bridge piece and floorboards, found that I had no up and down adjustment to get the gap right betwwen the legshields and floorboards. Obviously I knew that the horncast bracket was different as well.
soullad
lambytone wrote:You may find that they are slightly longer as well. I bought a pair for a series 1 project and have had to weld up and reposition the runner holes. Then when trying a dry build with panels, bridge piece and floorboards, found that I had no up and down adjustment to get the gap right betwwen the legshields and floorboards. Obviously I knew that the horncast bracket was different as well.
Have been told that the Eibar S2 leggies are identical in profile to Innocenti S1 leggies. Holes aside, would you agree?
    Users browsing this forum: Semrush [Bot] and 11 guests
