Oil seal gone !
flipster
Hello All,
Pulled off my rear hub today to find that brake shoes blatted in oily crap !
Final drive oil seal shot.So thats why I had trouble stopping !
So is it possible to replace the seal without major strip down ? (i.e. from hub side )
Please excuse my lack of mechanical know how but Im trying :?
Cheers in advance to all you spanner wielding whizz kids out there. :lol:
P.N.D.S.C.
ease as pie tbh , if it continues leaking tho its prob the o ring onthe layshaft which is a total gearbox strip
flipster
Thanks for the replies Eden, Mark. Hopefully it will be a simple job.
Otherwise I can see a trip to Ripon on cards :roll:
You busy Sean ? ;)
P.N.D.S.C.
Also check between the bearing and the casing I've known certain bearings spinning in the crank case causing oil leaks :shock:
Supereibar
Toddy wrote:Also check between the bearing and the casing I've known certain bearings spinning in the crank case causing oil leaks :shock:
:shock: Must be newly fitted bearings. The only bearings I know that fit in every single Li motor are RIV bearings. Whatever the public opinion is on them. They DO fit.
Both indian origin bearings don't know how long fitted when I found
    Users browsing this forum: Google [Bot], Semrush [Bot] and 4 guests
