Slip joints
Jeff T
Main scooter: GP150 & LI150 S2
Bit of a bodgers question I know but I've used silcone in the joints but still leaks and end up with black shite everywhere, anyone ever tried using heatshrink around the joints and will the heat of the exhaust cause a problem, I have got some that will fit and the spec is 110 degrees but not sure if it will cause a problem. Any ideas ?
cezeta
look on ebay there are rubber sleeves that you can lock wire or jubilee clip on, i wouldny use exhaust past as it can be perminant and ruin the exhaust
thats sets like cement so you might as weld it together.
any good? http://forums.ilambretta.com/viewtopic. ... ust+rubber
cezeta
yep thats them
i used to use radiator hose too
jonashford
What about at the stub? Any gud suggestions what to use there my franspeed is leaking like a gudn! nice black sh1t dribbling out of there. Ive got the rubber as above works a treat.
Too much oil in your mix
jonashford
Cud be gotta refuel soon so I'll remix fuel
cezeta
wurth do a hi temp matt black silicone sealant. its gggggreat.
it wil seal a slip joint or anything else you need sealing. if you spray the surfaces with brake cleaner first then it sticks like crazy.
i have re built engine mounts with this stiff and twigs before and it lasted from italy to the uk. also sealed a split petrol tank which lasted 500 miles or so.
jonashford
cezeta wrote:wurth do a hi temp matt black silicone sealant. its gggggreat.
Any idea what its called?
this came up on fleabay
only goes to 250 degrees tho,
cheers
