Vespa indicator problems
Modlife
Playstation gamer tag: iMarkG
Main scooter: Vespa T5 Classic
Hi,
Does anyone know what causes my indicators to stop working whilst the engine is revving high.
They work fine when the scooter is on tick over. My first thought was a problem with the voltage regulator, but I have since changed this and still have the same problem, I have also changed the flasher unit which made no difference.
Any thoughts would be appreciated.
Thanks
Modlife :wtf:
fraserp200e
Main scooter: 1988 MotoVespa TX200
Have you checked the sidepanel spring clips and frame catches are free from rust and have a good metal to metal contact? That's what provides the earthing for you indicators, I had the same problem on mine, I sanded down the clips and catch and now they work perfectly.
1983 Vespa PX125
1984 MotoVespa P200E
wack 63
Main scooter: '71 GP TS1
Also check the wiring at the back of the switch.
davepeters
Main scooter: px200efl
Have a look at the indicator earths in the toolbox as well. I attached them to another point and that solved a similar problem that I was having
vince
All the above is good indicator problem areas, there not much else...
Tuning on the tarmac dyno of life............
    Users browsing this forum: No registered users and 25 guests
